Regrouting Shower Tile
Old 02-16-02, 09:48 AM
psuphilly
I'm regrouting a tiled shower and was wondering if you grout between the last row of tile and the shower base or do you run a bead of calk in there. Any advice?
Old 02-16-02, 04:36 PM
T
Received 2 Upvotes on 2 Posts
Sealing joint between tile and tub
You need to run a bead of silicone caulk. Once your grout has cured, apply a couple coats of penetrating sealer. Follow manufacturer's instructions regarding resealing. Grout is porous and tends to absorb soils, oils, and stains.
