toilets
Old 03-28-02, 03:46 PM
malini
toilets
hai
my toilet flushes every 5 mins...by itself, i dont know whats wrong with that. to stop that.....i have to readjust the handle..some times that stops but i have to do that when ever we use it.
i'm looking for a solution
Old 03-28-02, 06:24 PM
L
Received 1 Upvote on 1 Post
Depends on what you mean when you say your "toilet flushes every 5 minutes..."
If you are hearing the tank refill every few minutes, the problem is the flapper valve, in the bottom of the tank. Replace it, and clean the seat that it seals against.
But if the water is draining out of the bowl (which it would only do once, unless you've got ghosts!!), you have a clog someplace. If this is what you are talking about, start with a toilet auger.
Old 03-28-02, 11:26 PM
malini
hai
thanks
i ment ...i'm hearing the tank refill every 5 min's
i will replace that
