Bathroom in Basement???
Old 04-26-02, 06:35 PM
mommie5
Question Bathroom in Basement???
We want to put a bathroom in home that we are purchasing? owner said we would need a up flushing toilet.. Is this true and what is it accually called?
Old 04-27-02, 07:04 AM
the_tow_guy's Avatar
Received 266 Upvotes on 217 Posts
Probably, since most houses' waste lines are higher than the basement floor.
Check this link:
http://www.saniflo.com/
Old 04-27-02, 09:21 AM
T
Received 2 Upvotes on 2 Posts
Installing bathroom in basement
Check with local building codes regarding code requirements and inspections.
Old 05-12-02, 02:07 AM
shack
When we put a bathroom in the basement, they installed a pump to flush "up" ... against the force of gravity. It has to be that kind of a pump in order to have enough force to work against gravity. Otherwise your basement bathroom would not smell pleasant.
