Leakin Toilet
Old 06-14-02, 07:38 AM
chess23389
Leakin Toilet
WATER IS COMING OUT OF THE BOTTOM OF THE SQUARE CONTAINER ON THE BACK OF THE TOILET , I CAN SEE THAT THE RING IS BAD BUT HOW DO I FIX IT ?
Old 06-14-02, 04:36 PM
notuboo's Avatar
This is the square box, or rectangular box , that holds the water?
If it is, simple fix.
Turn water off to toilet, remove old service line, use a sawzall or hacksaw to cut the bolts connecting the tank to bowl, bowl is now loose. Install new gasket, now would be the time to throw in a new fill valve, (fluidmaster A400), install new bolts, hook water line back up, give it a test flight....
Have fun....
