painting bathroom cabinets
Old 06-18-02, 06:11 AM
reba2451
Question painting bathroom cabinets
arial Does anyone have tricks or suggestions about painting bathroom cabinets......... They are currently a wood finish. I want to paint them a color. Need help on prep and type of paint.... etc......... Appreciate all replies...
Old 06-18-02, 03:18 PM
masterjoe
Talking Take your time....
I just completed the same project a month ago(Well, I painted kitchen cabinets as well). It turned out great and we're lovin' it.
First of all, you want to purchase a quality primer and paint.
It's not worth saving a few bucks going with a cheap paint.
I used Kelly Moore's with Zinsser 1-2-3 primer.
Here are the steps that I took:
1. Either sand or apply de-glosser to remove gloss from the surface; use a palm sander or a sanding block with 120 grit.
2. Wipe well with tacky cloth to remove all debris from the surface
3. Apply a primer with a good brush(It pays to use a good one)
4. Wait about 1-2 hrs and apply another coat(lightly sand in between)
5. Wait 3 hrs for primer to cure
6. Apply 1st coat of paint
7. Wait a few hrs
8. Apply 2nd coat
9. Wait 1/2 day for cure
10. If high gloss is desired, apply a high gloss top coat
*It'll be better to remove doors & drawers and do the above steps separately
Good luck!!
Old 06-22-02, 10:04 AM
reba2451
MasterJoe....
That was such a big help..... THANK YOU SO MUCH!!!!!
