toilet
Old 07-04-02, 09:12 AM
pbrackbill
Angry toilet
I HAVE A PROBLEM IN THE BATHROOM THE TOILET WILL NOT FLUSH ALL THE WAY DOWN? WE ARE ON A WELL, THIS HAS BEEN GOING ON FOR A LONG TIME . EVEN WHEN THE BATHROOM IS NOT IN USE VERY OFTEN.
Pauline
Old 07-04-02, 09:16 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
A toilet has its own built-in trap and almost anything can get hung up in it (plastic toys, toothbrushes, curlers, etc.).
If a bell-shaped toilet plunger doesn't work, get a crank-handle toilet auger, feed the auger into the trap through the bowl, and crank away.
If that doesn't dislodge the problem, you may have to pull the toilet and auger it out from underneath.
Do a search in here about clogged toilets. There are numerous posts.
It could be something other than a clogged trap.
Good luck!
Mike
