Storm Door Parts
Old 09-08-02, 07:24 AM
Daniel Otten
Exclamation Storm Door Parts
My daughter recently damaged the bottom panel of my aluminum storm door. I appears ro be only a fancy sheet of aluminum with a designed etched in. I have searched the Internet and went to the manufactures web site and can not find this part. The door function normal so I don't wish to replace the whole door..
Your thoughts???
Old 09-08-02, 12:38 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
You'll have to get this from the manufactuer of the door (which you probably will not be able to determine) or remove the existing one and go to someone who sells custom storm doors. It's easy to remove but more difficult to install. Remove the door and remove the bottom rail. The kickplate will pull out. The new one must be the EXACT dimensions. Clean out any caulk or glue and reverse the procedure. This is all eaiser said than done!!!
