"Barely" Sliding Glass Door
Old 12-12-99, 02:50 PM
Guest
Post
How do I fix a 'barely' sliding glass door so that it slides easier?
Old 12-13-99, 01:33 PM
Guest
Post
Hi beemerbob
can you describe the doors to me in detail as I am in the UK, most sliding doors are roughly the same, but are the wheels on the btm? normally they are, is the door metal or vinyl? what type of suround seal is used ie is it a rubber gaskett or is it a woolpile type of seal this is the most common over here, can the wheels be adjusted? if you can give me more info I will hopefully try to help you. Handyman
