Door casing
Old 03-27-00, 05:51 PM
Question
Recently I removed door casing during a minor renovation. The renovation did not involve the door directly, the casing was removed as a precaution. The door operated fine until the casing was replaced using new nails and the old nail holes. Now the door is a little too snug. It opens and closes but requires a bit more effort than it did before. What happened and what can I do?
Old 03-27-00, 06:26 PM
Post
Where does it pinch? When you removed it were there any shims? If so, have they been replaced?
You might try following the directions that I gave [email protected] on hanging a door.
It sounds like it needs a little attitude adjustment.
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
