Leveling a Sliding Closet door
I have sliding mirror doors on a closet.One side of an end door meets the wall at the bottom. However, the top is still about 2 inches away from the wall. The door rolls on steel wheels and the top has a groove which fits into a track. How do I correct this? Thanks for any help you can give.
Top,
Sounds like you have doors that are like bifolds. If they are, will have spring-loaded cylinder on top (should have adjustable plastic guide in upper track - move by loosening with screwdriver - and adjustable-for height (turn by hand up and down) on bottom. Also, can adjust on bottom for plumb- in and out - on little L-shaped tracks attached to base of door frame. If these are what you have, try that. Good Luck!
