Me too on the closet door!
Old 04-08-00, 11:08 PM
Guest
Question
I noticed there was another post up about this. I also can't figure out how to get my sliding closet doors off the track. I bought and assembled this great shelving unit to put in my closet. I thought I measured carefully enough, but I was off by about half an inch or so. I can't put it in the closet until I can at least get the bottom part of the doors off the hinges. PLEASE HELP!
Old 04-08-00, 11:12 PM
Guest
Post
Sliding closet doors that have both a bottom and top track usually require that you adjust the door (adjustments found on the top rollers) as high as necessary, or as high as possible to allow you to remove the guide pin from the bottom track. Hope this helps.
