Replacement window shimming
Old 04-09-00, 09:36 PM
Guest
Post
I am in the process of installing replacement windows and the widows are all going in very level. My question is do I need to put shims in the sides of the windows to brace them in addition to the mounting screws or just use the shims for correcting out of level windows. I have installed a couple without shims and they seem to be solid and level.
Old 04-10-00, 03:57 AM
Guest
Post
If your new replacement windows were measured right, you should not need any shims. However, life as it is, make sure you check each window. One may be a little out of whack and you will need a shim or two.
Good Luck. Make sure you calk both sides of your new windows.
Jack the Contractor
Guest
Post
What you want to level is the sill, BEFORE you put the window in, so that the bottom of the window frame is completly supported. Leave about 1/4" gap between the sides of the window frame and the trimmer studs, and a 1/4" between the top and the header.
