brick moulding/covering
Old 05-01-00, 09:42 AM
Guest
Post
I'm wondering if there is a vinyl product on the market for covering wood brick moulding around windows, to discontinue scraping and repainting. I know I can purchase aluminum coil stock and rent a brake and form a cover, but I'm hoping to cover it with something that has the graduated angles/shape like the original. Any suggestions?
Old 05-06-00, 04:03 PM
Guest
Post
Aluminum coil is the only way that I know. I did a web search and can not find any info for you.
A coil cover is meant to be a floating cover, not a skin.
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
Old 05-06-00, 04:11 PM
Guest
Cool
hey bob,most anyone who uses a brake can make you brickmold with a shape very similar
to the origonal(?)I make it all the time.If you would like directions on how to do it either post again or e mail me at [email protected]
Old 05-09-00, 10:24 AM
Guest
Post
Aluminum coil, with a PVC color coating on it, is available in a wide variety of colors and several textures. Call a local contractor who installs vinyl siding and they should be able to take care of you.
Old 05-09-00, 05:59 PM
Guest
Post
Aluminum is the only way. We do it all the time, and never use a brake. Good Luck
Jack the Contractor
