Aluminum Storm Windows
Old 05-16-00, 11:28 AM
Guest
Angry
I know the question has probably been asked, but is there no way to fix the broken frame corners of an aluminum storm window pane? The "L" shaped piece that holds the corner of the pane together is broken and I can't figure out if the pieces can be uncrimped and replaced. If not, can single panes (moveable and fixed) be purchased somewhere?
Old 05-16-00, 07:57 PM
Guest
Post
Replacing the "L" piece is probably not possible. Each mfgr. makes their own and they simply aren't available. Might try using a 1-1/2" flat "L" and attach it with sheet metal screws to rebuild the broken corners.
