Help! Installing a screen door!
Old 05-15-00, 09:51 PM
Guest
Question
I just bought a cheap ($45) screen door from Home Base. No instructions at ALL with it. I did a web search, but the only installation instructions I can find are for wooden screen doors. I need help! The side frame is about 1" longer... I assume I cut this off. It also came with a shorer length. Is this for the top? the side? I have no clue! The tool bag also comes with some straight pieces of metal about 2" long... what are those? I could really use some suggestions.
Old 05-16-00, 08:04 PM
Guest
Post
The hinged side needs to be cut to length. Attach that to the jamb then slide the door into it, flush at the top. Align the latch side of the door to the jamb. The short (36" or so) piece then attaches across the bottom to seal that off. Hope this helps. Not sure what the 2" pieces are all about.
