replacing french door with sliding glass door
If you're lucky, the french doors have a rough opening that will compatible with a standard slider, probably 6 feet wide. Simply remove the doors and their casing and you will have a rough opening. Expand or reduce that as necessary to get to the size you will need for the slider.
