sliding glass door repair
Old 07-23-00, 09:09 AM
Guest
Post
How do I replace the rollers in a very old sliding glass door?
Old 07-23-00, 09:52 PM
Guest
Post
Remove the sliding pane from teh frame and turn it on it's side so you can get to the rollers. Look them over VERY carefully to determine how they are installed and retained in the door frame. There are several ways that this might be accomplished, depending on the mfgr. and the style of roller used. Could havew screws holding the rollers in place, could have tabs on the side of the roller body retaining them, or could be relying on the weight of the door. Once you determine how to remove the old rollers, get EXACT replacements, and install them the same way. If you have a problem, call a competent glass shop.
quote:<HR>Originally posted by grauljwgraul:
How do I replace the rollers in a very old sliding glass door?<HR>
