cutting brick to create new window opening
I will add to casement windows to my home. I need to cut through my brick exterior (3 1/2" thick)to create my rough opening. Not sure what means to use to cut through the brick. Simply add a masonary blade to my circular saw or rent a larger masonary saw from Home depot. The circular saw seems easist, but the cut wont be completely through the brick, so I not sure it will work.
abrasive blades can be used to cut brick.they will wear,but they are cheap enough. set the guide on your circular saw to its deepest setting. don't forget to use googles.you can also use a pnuematic chisel if you own or rent a compressor.posted by joeman:
I will add to casement windows to my home. I need to cut through my brick exterior (3 1/2" thick)to create my rough opening. Not sure what means to use to cut through the brick. Simply add a masonary blade to my circular saw or rent a larger masonary saw from Home depot. The circular saw seems easist, but the cut wont be completely through the brick, so I not sure it will work. [/QUOTE]
Most homeowners don't own the saw that can do this job. A circular saw with a brand new masonry blade is not the answer.
A large demolition saw with a 10" or 12" blade is the answer. If you are familiar with their operation, rent one and do the job yourself.
If you are unsure of your DIY talents and skills, hire it out.
The cost of having it done right the first time is a good price to pay. Think of the alternatives?
