~Rough openings(door)~
Hello all,
I'm currently remodeling the basement & have a question on framing. I'm at the point now where I'm framing a non-load bearing wall that'll have three doors in it. What are the rough opening dimensions that I'll need? I'm gonna be using a 32", 30" & 28". I haven't purchased the door yet so I'm kinda stuck. I called Menards & I was told that I need the opening to be the door with plus 2". Does that sound right to you guys? I've measured one that was already installed & I'm figuring that I'll need only 1 1/2" over. That'll still leave me with room to shim. Your thought?
Edit: Or is that 1/2" gonna matter one way or the other.
Width of the door plus 2". The jambs will be 3/4" on each side (1-1/2" total), and you need to allow some room between the jambs and the trimmer studs to compensate for things not being plumb, square, straight, etc.
