pocket door
pocket door
What size opening is required for installing a 30in pocket door frame? I have'nt purchased the door frame as yet, but is building a partition at present and would like to leave enough space to install the door at a later date. Required openings for other size frames wil also be helpful if opening for 30in frame is not available.
Like always tks very much for the helpful responses.
You need to go ahead and purchase the door and frame....the frame has to be installed while you build the wall...the door you can mount later.
Previous Thread
Next Thread
