Sash window repair
Sash window repair
I have had three local firms in to mend windows. They are of the sash type and have metal spiral strips the length of the windows on each side. When the window is opened, the spiral does not rise with the window, it has freed itself from the inside top and remains hanging down. The window of course will not stay in the uo position.
On each occasion when supposedly repaired, the window did not have to be taken apart. Initially, these spiral strips were encased in a rubber type sheath which has either rotted or perished away. Since I presume these were actually cosmetic rather than essential, they were not renewed. It didn't seem to take much time when the repair men were working, about 20 minutes per window.
At this point I wish someone who knows how would come over to Nassau, because it seems beyond anyone local!!!!
Any ideas of where I could find instructions would be heaven-sent.
Hello Olwen!
Around here we call your type of windows "spring-lift sash."
Instead of having lead weights hanging on chains or ropes in side pockets to counter-balance the up and down movements of the sash your windows have spirals that act as spring balances.
They should be encased in a tube. The top ends of the spirals are suppossed to be attached with screws to the top of the jambs, and the bottom ends of the spirals are suppossed to be attached with screws to the bottom edge of the sash. The tension on the spiral can be adjusted if the windows don't stay open or are hard to close. This is usually done by a) removing the top screw b) holding the tube, c) turning the spiral (clockwise increases tension), and d) reattching the spiral with the screw.
It sounds to me like; a) the screws now being used will no longer hold your spiral and need to be replaced with a larger size, or b) the end of the spiral has broken off.
I sincerely hope that it's just that the screws are loose and fell out. Larger screws and some glue or epoxy might do the trick in this case.
There ARE replacement kits for your sash, (almost universal - just the sizes - lengths - vary) but they have become very difficult to find, and I do not know about the availabilty in your beautiful country. You may have to do an internet search and buy on-line.
Good luck!
OudeVanDagen
Good luck!
OudeVanDagen
Most manufacturers sdeem to be moving away from the spiral balance type of lifting mechanisms and are going with the 'force balance' type. Granted, if you can find a spiral balance, you can fix iut fairly rapidly and inexpensively, but can you afford to just replace the window? Maybe go to Home Depot, pick up a comparable type (wood if you have wood, vinyl if you have vinyl) and have a contractor put it in.
Good luck.
Good luck.
NO ADVERTISING IN FORUMS!!
Advertisements within the forums is not allowed.
Ads, advertisements, solicitations to buy or sell products, services or solicitations to hire a person, company to do work are not allowed within the forums.
Advertisement Policy and Disclosure Statements:
This forum topic nor any other forum topic on this web site was not intended to be used as a public bulletin board for the free posting of ads, solicitations and/or advertisements of any kind.
Forums and their topics where intended to be used to exchange helpful problem solving methods and solutions to questions and not intended to be used as a public advertisement bulletin board.
Unfit and inappropriate postings not relevent to the intent of this web site, postings containing ads, advertisements, solicitations or any such postings deemed as such by the hosts, administration, or moderators of the forums will be edited and or deleted without prior notice.
Kindly direct your advertisements to our advertisement department using the "receive advertising info" link provided on the bottom of every web page.
To solicit a contractor or company to perform services for you, please use the: "Get Matched with PreScreened Local Contractors" pictorial link provided on the top right hand side of every web page.
Do not use email communications or PMs to send ads, advertisements or solicitations to our members or moderators. Our members email addresses and Personal {PM} Message services are not intended to be used for advertisement or solicitations of any type.
Failure to comply with these policy rules, any part of the policy rules, will result in loss of membership privileges allowed on this web site.
If anyone has any objections to this policy, I encourage you to contact the website administrator directly and state your objection.
The "Contact Us" link is provide below for your convenience.
Website Host & Moderator
twelvepole
twelvepole
Spiral balances
C.R. Laurence http://www.crlaurence.com/ has plenty of sash balances of all types including spiral balances.
