Need bedroom door where none before
Old 04-05-03, 05:40 PM
BGC
We've moved to the finished basement of our townhouse. (The kids took over upstairs). The doorway to this room is framed on both sides and measures 35 1/2 at top, 35 5/16 at bottom, 6 1/2 deep. Height is 80 3/4 and 80 7/8 depending on where you measure. SIGH.
We thought about getting a 36 inch door and cutting it down, but we want a nice door and don't have the tools to make such a precise cut. So we've bought a solid pine 6 panel unfinished 32 inch door and some 2x6 in the hopes that some nails, caulk and molding will result in a proper fit. But its not too late to start over if you have a better suggestion?
Thanks, guys. You all are great!
Kay Lee
Old 04-05-03, 06:11 PM
camachinist
Maybe I'm missing something here but what I'd likely do if faced with these parameters would be to purchase a pre-hung 32" door and finish out the opening plumb and square to fit it.
Or, perhaps, your doorway is already finished out, although the tolerances you're calling out suggest a rough-framed situation. Perhaps a clarification is in order.
Let us know....
Pat
Old 04-06-03, 03:04 PM
BGC
Its done - we nailed the premium spuce (few knots) 2x6's to the sdes and the door fit perfectly. A little molding on the short sides, put the stops on, and the door looks and operates great. Now if only we could agree on a paint color . . . .
Thanks for your help anyway.
