rough openings
rough openings
what is the rough opening for a 32" and a 36" wide door, standard height. Also what is the rough opening of a 7x8' garage door?
Thanks
Thanks
32" door.......34" x 82 -82 1/2" ....... depends on how you plan to finish the floor.....IF you KNOW you're going to use 3/4" hardwood floor or tile w/ 1/2" wonderboard, I'd jack the door up 1/2" to 3/4" so the door bottom doesn't get too close to the finish floor level.....you might want to put a throw rug or mat on the floor and if you set it right on the subfloor, you might run short of room....
36" door........38 x by same deal on height
Garage doors generally have a finished opening of the "called" size.......so the "rough" opening would depend on WHAT you plan to finish off the opening with.....Personally, I use treated 2x lumber and cover that with aluminum trim coil, so my "rough" opening actually is 8x7 ( always width x height on doors/windows)...if you're going to use a 1x to finish off the opening, then your framing would be 3/4" more all the way around. If you're using a roll up door, the opening can be a fuzz less and you're fine, since the door actually fits in the inside of the wall plane anyhow.
