window boxes
window boxes
I don't know if I'm posting in the right place but, when hanging window boxes do you need the wooden brackets underneath or can you screw straight into the house from the inside of the box? I've seen window boxes with and without brackets on houses. I have vinyl siding also if it makes a difference. Thanks!
The key would be the intrisinc strength of the construction of the box. If they look sturdy, hang them up. I don't think the world will end if they start to come loose.
