Trim height for carpet install
What is the gap between the floor and trim work when planning to install carpet. Is it 1/2"?
Received 1 Upvote
1 Post
If you're talking about the baseboard, it can be directly on the unfinished floor, and a 3/8" gap between the baseboard and carpet tack strip will work fine for tucking the edge of the carpet.
Good Luck!
Mike
Good Luck!
Mike
Trim Height
You're right on target, I mean baseboard. Last time I did this I put several scraps of plywood under the base trim before nailing but I couldn't remember what size I used to get the right height for carpet install. 1/2" should do it, right?
