installing new knobs
Does anyone know a simple way for a novice to install new and slightly larger doorknobs on interior doors?
Received 1 Upvote
1 Post
You should be able to put new knobs on the squared threaded rod that fits through the existing lock mechanism.
Some door knobs have a set screw, and others work with a spring-loaded wire that you push in with a small flathead screwdriver.
Good Luck!
Good Luck!
