Framing out window
Old 08-10-03, 04:29 PM
F
Framing out window
Hello Folks, I'm in the process of ripping an old bathroom down to the studs. I want to make the window bigger as it will no longer be a bathroom. I plan on using a header and building it the right way. My question is will studs placed about 3 feet away from the wall on the joists hold the load while I adjust the rough opening. Also, I'm looking at the Andersen 400 double hung. Anyone know of a quality cost effective alternative??? Budget is a little tight. Home Depot has the Andersen for 220.00. Thanks in advance for your time. Eric
Old 08-10-03, 04:30 PM
F
Sorry, The andersen is a new construction 38x49. Thanks
Old 08-10-03, 08:38 PM
L
Received 1 Upvote on 1 Post
The temp. wall of 3 studs, placed about 3' from the wall, will work just fine.
The 3/0 - 4/0 Andersen window for $220 is about the best window you will find in that price range for that size.
