nrm
Old 09-29-03, 07:43 AM
nrm
Unhappy nrm
How do I fix a hole in a hollow core door. I know there are biscuits for this but I don't know how to use them.
Old 09-29-03, 11:10 AM
C
What kind of hole?
Biscuits?
Old 09-30-03, 05:43 PM
nrm
hollow core door
A hole in the door, like someone stuck a chair leg through it. Biscuits are oval pieces of plywood to repair the hole.
Old 09-30-03, 06:07 PM
C
You will need something to reinforce the patch, but trace around the biscuit and cut into the surface with an X-acto knife to make a matched seat for the biscuit. You culd probably glue some biscuits underneath as a support and set the surface biscuits on them when the opening is cut. After the glue sets, sand smooth.
Old 09-30-03, 10:23 PM
L
Received 1 Upvote on 1 Post
Not exactly the use for biscuits that the inventers of them had in mind, but if it works, who are we to argue??? ;-))
Old 10-02-03, 05:55 AM
nrm
hollow core door
Chfite
Sounds like a plan to me.Thank you. nrm
