Replacing Patio Screening
I hope this is the right forum for this question.
I have a screened patio. All screen frames are 1" wood with a slot routed on the edges facing the inside of each frame (10 screens). The existing screening is held in by splines in these routed grooves.
Last year I tried to replace the screening in some of the smaller frames and, while I managed to get it done, it doesn't look great and took forever. The corners are extremely difficult as you might imagine.
Does anyone have any tips or suggestions on an easier method to replace the screening in the remainder of the windows (large 60"H x 42" W, or thereabouts).
Thanks.
JimC
Thanks.
JimC
Jim,
Two questions:
Are you using fiberglass or aluminum screen? I think fiberglass works much better with spline. I replaced aluminum screen on my porch with fiberglass and I was amazed at how much easier it installed, and it tightened up beautifully. It is also holding up much better, which surprised me a bit.
Are you aware that there are different size splines? If you use the wrong size, it can give you fits.
Two questions:
I am using fiberglass. Have tried working with aluminum before and you are correct, it is very difficult to work with.
I used the same size spline that I removed, but that really doesn't mean it is the right size. I have also read somewhere about soaking the spline in warm water or some such to make it easier to get into the groove. Don't know about that one, though.
Thanks for your response.
JimC
JimC
If the old spline is rubber or vinyl get rid of it and get some foam spline at a local glass shop. It is easier to work with and yes, fiberglass is eaiser than aluminum screening to work with. Roll the screen material into the groove at the top first leaving about a inch beyond the groove and then roll in the spline.....now do the same at the bottom making sure that the screening material is taut. Repeat this on the left and right sides and then trim the screen material that's beyond the groove with a sharp utility knife.
