repair door hinge
repair door hinge
The screws for the hinges on my screen door are coming loose. It's a wood door, and the hinges are screwed into a wood frame. Simply tightening he screws is no good because the holes are now too big. How do I repair this? Thank you for your help.
Dave
Dave
Received 6 Upvotes
Hi: Dave
This thread may have all the answers to fixing the door hinges:
http://forum.doityourself.com/showt...threadid=162917
Loose hinges are the most common problem. How to fix them is contained in the link to an existing post in this forum. Should provide all the help needed....
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Regards & Good Luck
Web Site Host and Forums Monitor
Regards & Good Luck
