Installing a storm door on a Atrium door?
Old 03-26-04, 07:34 AM
phamby
the Atrium doors are like french doors, only one of the opens to the outdoors. Has anyone ever installed a storm door over the "opening" atrium door? If so, how did you do it?
Old 03-27-04, 01:16 PM
johnam's Avatar
Received 8 Votes on 8 Posts
Atrium door or french doors, as they are somtimes called, require 2 storm doors. To installed the doors you will need a french door kit so that you will be able to install an active door and a fixed door. The kit consists on an astragal, a continuous header, two hinge bucks and some miscellaneous hardware. We order our doors as "french doors". I don't know if the Home Depot's etc. can order them this way.
