Leaking vinyl replacement windows
I just replaced vinyl replacement windows and doors thru out my house. I installed them with a caulking adhesive, than I used a 25 year painters caulk on the outside (stucco) to seal any and all openings.
I did a water test the other day and found that some of them are leaking. Any suggestions out there how to best to seal them?
Any suggestions would be appreciated. my direct email is: rkstone@yahoo.com.
thks
Richard
thks
Richard
Leaking New Vinyl Replacement Windows & Doors
thks
Richard[/QUOTE]
thks
Richard[/QUOTE]
rkstone,
First, welcome to DoItYourself.com and the Window and Door forum.
Hate to tell you this, but you used the WRONG STUFF to seal them with. Check with several local glass shops around Studio City and see if any of them can get you Dow Corning Contractor's Sealant. If you can't find that, then use Vulkem 116.
It will be a pain, but you'll need to pull every window (one at a time), clean off the stuff you used, and reseal the window with the right stuff. The alternative is to let the windows leak for 4 or 5 years and then you'll be looking at $40K to repair the water damage!!
Lefty,you
What I used to seal the frame to the stucco was "G E 10 Clear Silicone Window and Door Caulk" and secured the windows. According to GE, this stuff is used for :Permanently flexible 100% silicone sealant adheres to wood, metals, concrete, masonry, stone, brick, glass, aluminum, vinyl, fiberglass, and most plastics. Lifetime satisfaction guarantee. Won't crack, chip, peel, or dry out. Gives a weatherproof and waterproof seal around windows, door, air conditioners, ductwork. Non-corrosive with metals. Not recommended for aquariums.
Than, I went back and used painters caulk around the vinyl frame as an extra precaution.
Is this still incorrect?
Thank you
Thank you
rkstone,
I've installed about 4,000 or 5,000 windows since the last time that I used silicon and/or painter's caulk. Well, OK -- painter's caulk -- I DO use that sometimes -- INSIDE!!!!
