Window Trim/Brick Mold Replacement
Old 07-26-04, 10:06 AM
mikedesc
I am planning on installing some replacement Pella windows on my aluminum sided house. Does anyone know of replacement or alternates to the wooden brick molding trim around the windows. I have seen some aluminum wrap for existing brick molding but do not know how to install it and the wizzes at Menards didn't know either. Is there any aluminum filler pieces available which could be used in place of the brick molds and fill the spaces between the window frame and the siding J channels?
Old 07-26-04, 01:34 PM
R
mikedesc,
You can buy cellular PVC brick molding from Home Depot or most lumber yards. You use pretty much the same installation methods as you would with real wood. All woodworking tools work well on the PVC. I would plan on using stainless fasteners in order to take advantage of the maintenance free properties you should expect. Use high grade silicone free caulk. If your current brick mold is a standard profile, then you should be able to find an exact replacement. The only catch is you shouldn't paint it in a dark color.
If installed properly, you can't tell it from real wood.
Old 07-26-04, 04:37 PM
mikedesc
nd in both cases, costs less than a buck a foot.
Old 07-27-04, 06:51 AM
mikedesc
PVC Brick Molding
Originally Posted by Randy Mallory
mikedesc,
Randy,
What is with the painting limitations with PVC, I need to paint it a medium tan to match my house, the wizzes at Menards didn't have any knowledge on the subject. They also have an extruded poly type of molding, is this any better for paint purposes?
Mike
Old 07-27-04, 08:22 AM
R
I believe the color limitations are due to potential heating from the sun. A medium tan might be OK. I would go to Home Depot or whatever supplier you want to use and see what brand of cellular PVC they carry, then check with the manufacturer. I would also think that the climate in your area would be a factor. However, the manufacturer would be the best judge of that.
I am not necessarily familiar with "poly." I may be wrong, but I believe there is a polyurethane product available as well as PVC. Also, PVC is "Poly" Vinyl Chroride. Could we be talking about the same thing?
There is a wealth of information available on the PVC products on the WEB from quite a few different manufacturers. I only suggested Home Depot since they usually nearby no matter where you live. I actually purchased materials to retrim the exterior of my house from a local lumber supplier. The actual dimensional "lumber" I used was the AZEK brand. The shingle molding and gable vents came from two different companies...I don't know the brands.
Anyway, I love the stuff. It's easy to work with and, hopefully, I will never have to replace my trim again. Apparently, paint holds up well on this stuff, too. Since it doesn't absorb moisture, the paint should not chip and peel like it does on wood.
Good luck,
