window privacy films
Old 09-03-04, 10:33 PM
JDavidson
Hi,
Are there any products available that allow one to convert a normal window into an window that provides 24hr privacy and view from one direction only (inside). Thanks!
Old 09-05-04, 06:19 AM
glasman2's Avatar
they make a mirror tint that can me applied to the "outside" surface of the window, but if you have a light on you see in not out.Never let a window tint Co install any kind of tenting on the inside pane of glass, they will tell you it's ok, but I'll tell you it's the fastest way to make a window go bad, or get a heat crack.Tenting is not %100 1-way incase this is your bedroom or something like that.
