Doors problem
Old 10-05-04, 03:01 AM
brale
Doors problem
At first i want to apologise for my Tarzan english.Here is my problem:
I'm setting the door, the gap was OK all around and the door closes and opens easily.When I put foam for doors the gap was extend and I now can't close the doors.What to do now?
Buy
Old 10-05-04, 07:03 AM
H
Expandable Foam?
Did you use expandable spray foam in the can?
If so you shouldn't have done so and it tells you right on the label not to use it around doors and windows...
(But don't feel too badly because I shut myself out of my own house using it that way once... )
If it is expandable foam, you need to chisel it out after it dries and use only some lightly back fiberglass if anything afterward.
Old 10-06-04, 12:32 AM
brale
Is there some other way to fix my doors I don't ready to chisel foam.Is it some way to liquate the foam and then extend stock, and leave the foam to dry?
Buy
Old 10-06-04, 05:11 AM
glasman2's Avatar
NO, you need to remove the foam. They make a non-expandable foam ( that you should have used ) . If you have a sheetrock saw ( looks like a big knife ) you can use that to cut on both sides of the foam and just push it out. It's not that hard and doesn't take long.
