Slider not properly mounted and open in an area to the outside
Our home we just bought has about an inch open on the sliding door open to the outside. This is on the bottom right hand corner. What can I do to remedy this? I have no idea where to start.
adjust the rollers, bottom left down, bottom right up. inside looking out.
at the bottom edge of your door you will see a hole, insert a Phillips screwdriver and clockwise is up, counter clockwise is down.
make sure you don't drop it to much and it drags.
If after doing this and it still isn't right, use a mallet at the top ( latch side )and smack it, this will square it up more.
