long term mineral stains on glass door
What is the best approach to a seriously stained glass door that has received a lot of mineral deposits from a sprinkler. Phosphoric acid ? What per cent? Other?
LimeAway works good. My wife has a janitorial Co. and uses that a lot.
Every once in a while she runs across some windows that it won't work on , or fast enough, then she uses a toilet bowl cleaner called 60 seconds " gloves and safety glass needed with this product. You can find it at most Janitorial supply stores
Test a small out of the way area of your house first, sometimes it will remove the paint or tarnish window frames.
to use 60 seconds. hose window, apply 60 seconds with a sponge and hose off fast, no real scrubbing needed
