Door Header
Door Window Replacement
I have several wooden exterior patio doors with full-length thermal windows which need replacement due to degredation of the seal, causing fogging within the window. I have the replacement glass units, but I am uncertain how to remove the old glass. I cannot determine by visual inspection whether the window trim is removed from inside or outside the door. I don't see any brads on either side of the door. Does anyone have specific knowledge as to how the removal and replacement should be done? Thanks.
I dont have any specific knowledge on this but my guess is that it would probably be from the inside.
There probably is trim pieces that can be removed.
Maybe someone where you got the replacements would know!
