confusing door lingo
First off, if this isn't your house, you should get the ok to even work on it.
If you work on it before asking, the owner could say you caused it and make you pay for any labor cost.
Have the people you rent this from look at it first, if they want to make a deal with you ( ie. rent reduction for you working on the door ) then come back. Your time is money to, so any deal you strike with the owners should include material and cost of your labor.
I agree with glasman on asking the landlord first. You could try opening the door and looking at the hinges to see if they are loose. Wiggle the door while it is open and see if the hinges move where they are attached to the frame and on the door itself. Good luck.
