Install a new front door
I just want to replace my old front door with a new front door...
The old: solid wood, warped a little, old...
The new will be: steel
Do I need to take out the whole casement and replace or can I just take the old door off the hinges and put the new steel door in the same spot?
Thanks much!
Thanks much!
I would think that you could replace just the door but make sure it will fit correctly in the old frame. If the old frame is out of plumb or twisted, a new door will not solve your problem. Below is a link that may be helpful. Good luck on your project.
http://www.doityourself.com/doors/ex...stormdoors.htm
