Remove Security Door
The security door is attached to the wood frame with kind of screws that you can tighten only. Is there any trick to unscrew? I plan to grind off the screw heads with a grinder but don't know if you guys have better idea?
Another member had the same problem and got some very good ideas. You might try some of these. Click on or copy and paste the link below.
http://forum.doityourself.com/showthread.php?t=188933
Good luck and reply back if you have further questions
Any store that sells security doors probably also sells the extractor for those screws. Comes in a little kit that includes an allen wrench for setting the extractor to the proper depth, along with instructions on how to use it.
