Are Window Sill Pans Necessary in a Dry Climate?
I've just bought some Jeld-Wen Caradco clad-wood windows and I notice that the installation instructions include a fairly elaborate sill pan arrangement. I live in Santa Fe, New Mexico and we have a pretty dry climate. Is the sill pan overkill?
Part of my reason for wanting to avoid the sill pan is that my windows have nailing fins, but I'll be installing them in a concrete block wall with a 2x4 buck frame. This particular combo is not covered by the Jeld-Wen docs and I'm not exactly sure how to adapt their sill pan instructions...
Cheers,
Sy
Cheers,
Sy
Not Necessarily So
Flashing is required around all windows and doors except where the nailing fin is described as 'self flashing', is at least 1 1/8" wide, and covers the exterior sheathing so as to prevent water infiltration.
Unless your window fins extend beyond the 2x window bucks and cover the seam between the masonry and the framing lumber, you will need to flash around the entire window in a code approved manner covering the nailing fins in the process.
It does not matter how 'dry' your climate is. Flashing is required at all times in all locations.
You should rely on your local building code for specific flashing instructions and not trust the generalized mounting instructions that is supplied by the window manufacturer.
As far as flashing goes, it is ALWAYS in one's best interest to flash even over 'self flashing' windows.
he was asking about a sill pan, not flashing, Like a sill pan under a sloped DH window.A sill pan is used where no fins are applied on the bottom , to level and seal the bottom. Yes every window ( reguardless if it has fins ) needs to be flashed.
