Water On Window Frames
Old 01-06-05, 04:54 AM
kkmcewen
Is It Normal For There To Be Water On The Metal Frames Of Windows. The Outside Temp Was 30 And The Humidity Level In My House Is 40 Percent. The Water Is Only On The Aluminum Frames And Not The Glass.
Old 01-06-05, 09:39 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
yes it commom.
Aluminum is not a good insulation against cold .
It will condense with different temp.
Old 01-06-05, 10:38 AM
kkmcewen
Will The Water From The Frames Destroy My Wood Sills After Some Time? If It Will Is There Anything I Can Do To Stop It?
Old 01-06-05, 02:31 PM
Bob53's Avatar
hi, keeping your wood sills with a good coat of paint that is not peeling should keep them good, assuming they are pretty smooth and have a good finish to begin with.
-Bob
Old 01-08-05, 03:36 PM
W
Received 13 Upvotes on 11 Posts
Hi, Check to see if the windows have weep holes in the bottom frame. They may be plugged.
Good Luck woodbutcher
