extension jambs for half round
Old 01-08-05, 07:59 PM
perplexed33
Question extension jambs for half round
I have installed a half round window but need additional extension jamb of about 4 inches...the wall is 10 inches thick so the 6 inch jamb that came with the window is not sufficient. Any ideas on how to make Jambs for this window. Thanks
Old 01-09-05, 05:24 AM
L
Received 1 Upvote on 1 Post
Across the sill is easy, since it's straight. Check the moulding and trim section of any big box store or lumberyard and you will find window stool. For the arched section, you can cut strips of 1/8" plywood (luan works, since it has no knots and virtually no other defects) and bend them in place, one at a time, until you have the desired thickness.
Old 01-09-05, 07:04 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
There are also flexible mouldings that are a bit costly and maybe not easy to find. Start with this website: http://www.flexibletrim.com/
