Metal door frame
Old 02-08-05, 05:51 AM
O
Received 1 Upvote on 1 Post
Metal door frame
I am building a room in my basement that will be a little more secure for some of my stuff. The door and door frame I got are both metal that are used in commercial buildings(both are fire rated) The frame is made for a 2 x 4 wall with 1/2" sheetrock on both sides. My question is I dont know the proper way to frame the opening for the door frame. there are pockets inside the frame for the hinges and the lockset. Do I just notch around these? There is one screw on each side of the frame that has a bracket to hold the frame in. Does this bracket go thru the 2 x 4 then get screwed to the frame? The frame is made by Curries company, it comes in 3 pieces and snaps together and can be screwed together at the top.
Thanks for any help.
John
Old 02-08-05, 12:13 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
You might find the answers to your questions here: http://www.curries.com/index.htm
Old 02-08-05, 03:23 PM
O
Been there, looked, and they dont show what I need. All they give is the dims. for the frames not the wall that it attaches too.
Thanks anyway.
Old 02-08-05, 06:55 PM
There should also come with this frame two additional brackets which mount at the base of the jamb legs. The stiff part goes inside the jamb and the two ears, with holes in them, fold to form a "U" and fit around the bottom plate and are secured there with screws.
As I recall, we usually use welded, timely or Western Integrated, the rough opening width is 39" for a 36" door and 82" in height.
You set the door frame in the rough framing PRIOR TO DRYWALL and plumb using the screwdriver adjustable brackets at the top of the jamb legs.
The drywall will fit behind the frame all around.
Old 02-08-05, 07:12 PM
2
Even though your installtion probably isn't rated fire doors & frames are installed according to:
1. The manufacturer's instructions
2. or ANSI/DHI A115-IG "Installation Guide for Doors and Hardware"
3. or HMMA840-99 "Installation and Storage of Metal Doors and Frames.
http://www.naamm.org/hmma/pdfs/HMMA840-99.pdf
AND
NFPA-80 for fire rated assemblies
Old 02-09-05, 04:32 AM
Thanks for the link.
Nothing on curries web site.
Old 02-09-05, 06:14 AM
O
Thanks alot guys, that link really helped. The frame that I have evidently goes up after the drywall, it has screw holes on the outside of the frame at the bottom and a bracket at the top on each side I figured out was for pressing against the 2 x 4 frame instead of pulling against it to plumb it square.
Thanks for the help.
Old 11-22-07, 04:05 PM
G
Interior fire-rated door for furnace room
Sorry. I deleted my original message and started a new thread.
Last edited by GaetanoL; 11-22-07 at 04:07 PM. Reason: Deleted. Error in posting. New thread started.
