Door casing
Old 02-16-05, 09:28 AM
Door casing
I recently put new casings on my door.They are the fluted type with the squares in the corners so you don't have to miter.I left a reveal around the door frame.My trouble is the door latch hits the casing when you close the door.The strike plate does not come out far enough to catch the door latch.Where can I get the right strike plates?Or anything else.
Old 02-16-05, 10:25 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
you can get longer striker at your hardware store cheap
good luck
pg
