Anderson 200 series vs. 400 series
Other than cost, is there any benefit going with the 400 series Anderson windows vs. the 200 series? I believe the frame on the 400 series is slightly thicker but I'm wondering if the insulating value makes enough of a difference to justify the additional cost. I'm looking at 22 windows plus a bay and the 400 series is about $100 more per window. That seems like quite a bit of cost to recoup. Thanks for any input.
Not sure what style of windows you're looking at.
Series 400 windows: Casement/ Stationary/ Awning, Woodwright Double-hung, Tilt-wash Double-hung, Bay & Bow, Gliding windows, Specialty windows
Series 200 windows: Casement/ Stationary/ Awning, Narrowline Double-hung, Tilt-wash Double-hung, Bay & Bow, Gliding windows
If you're looking at Casements, the difference is the glass. $100 per upgrade for better glass sounds about right.
Additionally, besides better glass, the 400 series Woodwright, tiltwash and glider are all a better window than 200 series Narrowline, tiltwash and glider. The difference is mainly that the 400 series windows have less wood / more composite in the exterior half of the frames reducing the potential of rot, while the 200 series has vinyl clad wood sills and jambs.
If you have specific questions such as how the u-factor or SHGC (solar heat gain coefficient) compare, I have Anderson's product guide handy.
Thanks for that good information. One of the windows is a casement and the other 21 are double hung. The bay will also include 2 casements. We don't plan to move so we want the windows to last a long time. For energy purposes and longevity it sounds like the 400 series is the better option.
Andersen Windows
There are several differeces in the 3 models of Andersen windows. (200, 400, and 400 woodright)
200 - no custom sizing, few finish options, few hardware options,all wood window, no vinyl cladding on the outside.
Primarily a new construction window.
400 - no custom sizing, more finish options, more hardware options, all wood window, no vinyl cladding on the outside.
400 Woodright - custom sizing, the most finish options, the most hardware options, all wood composite window, with vinyl cladding on the outside.
Can be used for new construction or retrofits due to custom sizing.
