Caulking window screens
Not all of my alum framed mesh window screens fit tightly. I am seeking a product to caulk or otherwise seal the screens to prevent pest access to the interior. Any suggestions?
You likely don't want to just use ordinary caulking, because someday someone is going to want to take those screens out, and boy will they cuss the guy that caulked them.
So I'd recommend a caulking such as Dap Seal-N-Peel. It's not quite as permanent as caulking.
You're welcome! Keep in mind that when it rains, and water passes through the screen, it will need to get out somehow. So you might want to leave a weephole at the corners, or not caulk the bottom at all. If you dam water up, it might go someplace you don't want it to.
