Window Removal & Questions
1. What is my wall probably made of?
2. How do I remove what seems to me like a metal frame window?
3. Should I just hire someone to remove it?...I've heard it's difficult to do.
Sorry this is so long. Any little tips would help.
Thanks! Christine
hi
Here is some suggestion
might be 2x4 or 2x6 with insulation bettem the header and the bottom part if it was an exterior wall before and depending climate
start by removing the trim around. some windows where attach with screws in the window frame or where fasten from the outside. check if there a flage around the exterior part of the window.
If you have the tools and some help you should be able to do it or get a friend that has some capentry skills.
All you need is to remove the window, install some 2x4 or 2x6 to fill in the gap place them 16" cc and then cover the hole with drywall
tape, mud, sand, prime, paint
good luck
pg
