code for door locks/handles
Old 05-12-05, 06:16 AM
Pendragon's Avatar
Received 2 Upvotes on 2 Posts
Is there a code requirement for the height of door locks, handles and other securing devices for doors?
Old 05-12-05, 06:30 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
the standard heigh for door handle is 36 inches center from the floor and the deadbolt is usually 6 inches higher from the door handle
pg
Old 05-12-05, 07:32 AM
Pendragon's Avatar
Is there something in code, or are these just 'suggestions'. ie, is there anything that says you shouldn't put a deadbolt 6' up on a door?
Old 05-12-05, 09:15 AM
pgtek's Avatar
hi
these are stnadard in the trade for door handle and deadbolt.
why 6 ft???????????????
ever think in an emergency to unlock it 6 ft high
here some detail on door handle
Most doorknobs are 34 to 38 in. high, with dead bolts 6 to 12 in. above that. Decide for yourself what height is comfortable. When drilling new holes, tape the manufacturer's template in place with the lockset centerline at the desired height. Determine the backset—the distance from the door edge to the knob centerline—and use the corresponding template marks. The backset can be 2 3/8 or 2 3/4 in.; many locksets accommodate both. Then drill 1/8-in. pilot holes through the door to center the 2 1/8-in. hole saw. At the door edge, use the template to drill a 2-in.-deep pilot hole for drilling for the strike or bolt.
